Port Subdivisions
On some Extreme Networks switch models, you can configure QSFP28 ports either as single ports or as multiple, partitioned ports in Switch Engine, or channelized ports in Fabric Engine. In a partitioned or channelized port, with appropriate cabling, the original physical port can accommodate multiple data lanes at lower bandwidths. Ports are not partitioned by default.
The following options are available:
Table 1. Port Partitioning/Channelization
DevicePort BandwidthPort Partitions/Channels
5720 Series (all models)
QSFP28 (U1 and U2 ports)
100 GbOne U1 or U2 port with one of the following:
  • One 100 Gb port (default)
  • Two 50 Gb ports (Switch Engine only)
  • One 40 Gb port
  • Four 25 Gb ports
  • Four 10 Gb ports
5720-VIM-6YE
SFP28
25 GbThe 5720-VIM-6YE has two speed groups, each with three ports that can be partitioned with the following:
  • Three 1 Gb ports
  • Three 10 Gb ports
  • Three 25 Gb ports (default)
5720-VIM-2CE
QSFP28
100 GbThe 5720-VIM-2CE has two ports, each of which can be partitioned with the following:
  • One 40 Gb port
  • Four 25 Gb ports
  • Four 10 Gb ports
For information about configuring partitioned ports, see the Switch Engine Command References for your version of the Switch Engine operating system, or the Fabric Engine Command References for your version of the Fabric Engine operating system.
