Antenna Specifications
The AP4020FX supports the following antennas.
External:
  • Two (2) single band 6 GHz antennas
  • Two (2) dual band 2.4 GHz and 5 GHz
  • One (1) dual band 2.4 GHz (IoT) and 5 GHz
  • One (1) single band 5 GHz
Internal:
  • IoT Radio 1: Selectable between internal and external
  • IoT Radio 2: Two (2) selectable internal antennas
  • One (1) 2.4 GHz/5 GHz/6 GHz sensor
