Micro USB Cable
Use the console port to make a serial connection between your management system and the access point. You can order a micro USB console adapter for your access point using the part number ACC-WIFI-MICRO-USB.
When you connect to the Micro USB console port, the management station from which you connect to the device must have a VT100 emulation program, such as TeraTerm Pro (a free terminal emulator) or Hilgraeve HyperTerminal (provided with Windows operating systems from XP forward).
The console port can only be used with the Extreme Networks console cable. You could damage the AP if you use another cable.
Micro-B model Console Port Pin Information
Image of gray micro USB port pins stacked aside each other with numerical call outs from 1 to 5.
Table 1. Micro-B USB Pin Information
Pin number Pin name and description
1 NC
2 R×D (input to access point)
3 T×D (output to terminal)
4 Signal (GND)
5 Signal (GND)
