Power Profile
The following tables show the AP4020FX power profiles for the radio modes. Use this information to plan for power consumption as you deploy your APs.
Table 1. AP4020FX 802.3at Power Profile|
| Radio 1 | Radio 2 | Radio 3 | 1x1 Sensor | Ethernet Ports | USB |
| Radio Mode 1 | 2.4GHz (17dBm), 2x2 | 5GHz (18dBm), 2x2 | 6GHz (18dBm), 2x2 | Yes | Yes | 2.5 |
| Radio Mode 2 | 2.4GHz (17dBm), 2x2 | 5GHz High (16dBm), 2x2 | 5GHz Low (16dBm), 2x2 | Yes | Yes | 2.5 |
Table 2. AP4020FX 802.3bt Power Profile|
| Radio Mode 1 | 2.4GHz (17dBm), 2x2 | 5GHz (18dBm), 2x2 | 6GHz (18dBm), 2x2 | Yes | Yes | 2.5 and 5.0 |
| Radio Mode 2 | 2.4GHz (17dBm), 2x2 | 5GHz High (16dBm), 2x2 | 5GHz Low (16dBm), 2x2 | Yes | Yes | 2.5 and 5.0 |
Table 3. AP4020FX 802.3af Power Profile | Radio 1 | Radio 2 | Radio 3 | 1x1 Sensor | Ethernet Ports | USB |
| Radio Mode 1 | 2.4GHz (17dBm), 2x2 | No | No | Yes | Yes | No |
| Radio Mode 2 | 2.4GHz (17dBm), 2x2 | No | No | Yes | Yes | No |
802.3af is not recommended as an operational mode.
