ExtremeWireless AP4020FX Installation Guide
Features and Specifications
> Physical Specifications
Extreme Networks, Inc. December 01, 2025
Abstract
Preface
Purchase Information
Environmental Specifications
Antenna Specifications
Radiation Patterns
Ports, Connectors, and Hardware Features
Radios
Power Options
Power Profile
Enclosure
Accessories
LED Descriptions
Micro USB Cable
Cleaning Guidelines
Installation
Installation Workflow
Pre-Installation Tasks
Box Contents
Onboard the AP with the ExtremeCloud IQ Mobile Onboarding Application
Wall and Ceiling Installations
Install the Access Point on a Wall or a Flat Ceiling
Install the Access Point to a Wall with AH-ACC-BKT-AX-WL
Install the Access Point on a Standard Flat Ceiling Rail with Sculpted Ceiling Tiles
Install the Access Point on a Silhouette Ceiling
Install the Access Point to a 9/16-inch T-bar Ceiling
Install the Access Point on a 15/16-inch T-bar
Install the Access Point to a 1 1/2-inch T-bar with an ACC-BKT-AX-TBW
Non-standard Ceiling or Wall
Install the Access Point on a Beam
Install the Access Point on a Junction Box
Connect the AP to the Network
Connect to a Power Supply
Lock the Access Point
Antenna Connectors
Connect the Optional Antennas
Regulatory and Compliance
Country of Manufacture
Professional Installation Instructions
Safety Guidelines
FCC Notice (Part 15 - Class B)
FCC Radiation Exposure Statement
Industry Canada Notice
The
AP4020FX
has the following dimensions and weight:
Dimensions: 9.65 in. x 9.65 in. x 1.69 in. (245mm x 245mm x 43mm)
Weight: 3.1 lbs (1.40 kg)
