Configure Interface Settings for Engine Application
Use this procedure to configure the final
application interface settings immediately ater you deploy an application. You can use
these settings to assign a VRRP IP alias to the application (which is required for some
applications).
Refer to the documentation for your engine application
for application-specific requirements. Configuration requirements can vary
per application.
Go to the application interface settings page for
your application.
The page launches automatically after you
select the Deploy
option for a newly installed application. Otherwise, go to Engines > Installation and then select the link for the engine instance.
Take a copy of the Locking ID (Serial Number).
Most applications require you to provide this value during license
activation.
Optional. If your engine application requires you
to configure a VRRP IP alias:
Select the Network Service
Configuration tab.
From the Assigned Virtual IP
Address field, select a VRRP address that you assigned
previously on a data port.
Select Save.
Optional. To launch the application user
interface, select the Instance Web
Interface link.
