VRRP Configuration (Optional)
The Universal Compute Platform relies on Virtual Router Redundancy Protocol (VRRP) to provide IP abstraction to key functionality.
Some applications request that you configure a VRRP address for access to that application's management interface. VRRP can be used to configure an IP alias with pass-through capability for the Universal Compute Platform data interface to that application's management interface.
If you are using VRRP, the following settings must be defined for the VRRP configuration on a data port:
For details, see Add a Port.
