Use this procedure only if you are installing and
configuring the standalone cluster while offline. In this case, you must upload and
install a Kubernetes image before you create the cluster.
For online installations, you can skip this procedure as
Kubernetes installs automatically when you create the standalone
cluster.
Go to Administration > System > Software Upgrade.
Select the Kubernetes tab.
Upload the image file using one of the following
two methods:
On the Kubernetes page,
select (Upload Kubernetes resource package
zip file) and then browse to the image file and select
it.
On your desktop, select the image file
and drag it into the Upload
Kubernetes resource package zip file area of the Kubernetes
page.
The image file uploads to
Universal Compute Platform and then installs automatically.
If you want to delete an
Available image, select the adjacent (Remove
Mirror).
