Validate the IP addresses that you configured previously through the Configuration Wizard.
If you want to configure a port interface, or add a VRRP alias that can be used by an engine application, go to Add a Port.
Configuring an engine instance IP address for the admin interface of the container application is useful for diagnostic purposes. The web interface can be accessed from the Engine Settings.
