Configure Access Control Group
To configure an Access Control Group, take the following steps:
  1. Go to Onboard > Groups > Add.
  2. Configure the following Access Control Group settings and select Save.
    The entry parameters depend on the Group Type. Access Control Group Settings describes each setting and provides an example value configured for the Access Control Group.
    Table 1. Access Control Group Settings
    FieldDescription
    NameGroup name. Example: Captive Portal Admins
    DescriptionDescription of the group. Allows Self Registration.
    Group TypeCriteria by which the accounts are grouped. Example: End System — MAC
    Group ModeFor End System LDAP User Groups only — Specify whether to match any or match all of the LDAP attributes. Valid values are:
    • Match All
    • Match Any
    Example: Match Any
    Group EntriesA list of entries for the Group Type.
    Example: End System — MAC. Use the Search field to search for an entry.
    Access Control Group Configuration: Captive Portal Admins
Next, review the Default Access Control Groups, then we will create an Admin access policy role.
