<?php
// This file contains PHP associative arrays holding the relatively
// static configuration for this ECP application. A real application
// might read the data in from an XML or '.ini' file.
// An associative array of identity => shared secret pairs.
// This example only uses the first one. Any printable ASCII
// alphanumeric string can be use for the identity and shared
// secret so long as both the ECP and the controller use the
// same pair.
$awsKeyPairs = array(
'BigAuthInc'=>'secretferqrer123456667',
'testingidentity1'=>'secretferqrer123456668',
'testingidentity2'=>'secretferqrer123456669'
// Aws Signature-related Configuration
// Region and service are used to build the scope.
// Expires is the maximum amount of time the signed URL
// should be trusted.
$awsConfig = array(
'region' => 'world',
'signature'=> 'v4',
'service'=>'ecp',
'expires'=>60
