Configure Admin Access Policy Role
Configure a Policy Role that allows Admin access to the captive portal Admin page using Port 8445. Role Parameter Settings describes each setting and provides an example value configured for the Captive Portal Admin Role.
  1. Go to Configure > Policy > Role > Add.
  2. Configure the following Role settings:
    Table 1. Role Parameter Settings
    FieldDescription
    NameName of the Policy Role. Example: Captive Portal Admin
    Bandwidth LimitSelect this option to allow unlimited bandwidth. Select to set the Class of Service value.
    Default ActionDetermines the access control default action. If you do not define policy rules for a role, the role's default action is applied to all traffic subject to that role. Policy Rules affect traffic that meets the filter criteria.
    Example: For Role Captive Portal Admin the Default Action is Deny. Deny packets that do not match a filter rule or deny packets when a filter rule does not exist.
    When a packet does match the filter rule action Allow packet using the specified VLAN GTAC (222).
    VLAN IDPolicy roles default to the VLAN specified during network configuration. You can specify a unique VLAN here. Select to add a new VLAN option.
    Example: GTAC (222)
    Associated ProfileIndicates profiles that this role is associated with. In our example, Role is not associated with a Profile.
    RulesSpecify the following L3 L4 Rule:
    Example: Allow traffic from IP/Subnet 22.222.2./32 through Port 8445.
    Admin Access Policy Rule Configured for Port 8445
Next, configure the Access Control Rule.
