An Access Control Rule is used to further define an end user's network access based on the groups and policy roles with which the end user is associated.
To configure an Access Control Rule, take the following steps:
Field | Description |
Name | Rule name. Example: Lab40-ICP Admin |
Rule Enabled | Check to enable this rule. |
Conditions Note:
User-Group | Any. No specific group configured. |
End-System Group | The end-system
group that you configured in Configure Access Control Group (Captive
Portal Admins). End-systems that do not match any of the listed rules are assigned the Default Catchall rule. |
Device Type Group | Any. No specific group configured. |
Location Group | The location group that you configured that is affected by the rule. SSID: Lab40-ICP |
Accept Policy | Associate a policy role with the Access Control Rule. Example: Captive Portal Admin. We configured this policy under Configure Admin Access Policy Role. The Default Action is defined in the policy rule. |
Portal | Associate a captive portal with a rule. Our example uses the Default. |
Next, review the Default Access Control Rules, then go to Onboard > Rules to define the rule precedence of the Access Control Rules.
Section contents:
