ExtremeCloud IQ Controller Default Pass-Through Rule
Create a RADIUS Pass-Through rule on ExtremeCloud IQ Controller. This rule designates that traffic connecting to the Guest network will send and receive all RADIUS requests from the externally defined Access Control Engine server, not from the ExtremeCloud IQ Controller that processes the request. This includes filter-ids that are received as attributes. The ExtremeControl Access Control Engine provides RADIUS authentication and authorization and policies that are defined in ExtremeCloud IQ Site Engine.
  1. On ExtremeCloud IQ Controller, go to Onboard > Rules > Add.
  2. Configure the following parameters:
    Name
    Guest
    Rule Enabled
    Select this option to enable the new rule.
    Location Group
    SSID: Guest
    Accept Policy
    Pass-Thru External RADIUS
  3. Select Save.
  4. Move the rule to the top of the rule set, if it is not already there.
Guest Rule ExtremeCloud IQ Controller
Guest Rule Settings for Controller
