For information about advanced RADIUS configuration settings, see the following table:
| Field | Description |
| Username Format | Determines if the domain name will be included in the username when proxying a request to the backend RADIUS server. Valid values are:
| Require Message-Authenticator | Protect against spoofed Access-Request messages and RADIUS message tampering with this attribute. The Require Message-Authenticator provides additional security when using PAP and CHAP security protocols for authentication. EAP uses the Message Authenticator attribute by default. |
| Health - Use Server Status Request | Use Server-Status RADIUS packets, as defined by RFC 5997, to determine if the backend RADIUS server is running. |
| Health - Use Access Request | Use an access request message to determine if the RADIUS server is running. The request uses a username and password. This method looks for any response from the server. The username and password do not need to be valid. A negative response will work. However, the username/password fields are provided to prevent rejects from being logged in the backend RADIUS server. |
| Check Interval | Determines the wait time between checks to see if the RADIUS server is running. Note: This is only applicable if the Server-Status request or Access request methods are used.
| Number of Answers to Alive | Determines the number of times the RADIUS server must respond before it is marked as alive. Note: This is only applicable if the Server-Status request or Access request methods are used.
| Revive Interval | Determines the wait time before allowing requests to go to a backend RADIUS server, after it stops responding. Note: Use this option only when there is no other way to detect the health of the backend RADIUS server.
If Server-Status requests option and Access request option are not supported by the RADIUS server, then use this option. |
| Require Message-Authenticator | When enabled, the message-authenticator attribute value pair is included in the packet from the RADIUS server. |
| Health — Use Server Status Request | Determines if the Server Status Request is used to determine RADIUS server health upon recovery after the server has gone down. This is RADIUS status code point 12 from RFC5997. |
| Health — Use Access Request | Determines if the Server Access Request is used to determine RADIUS server health upon recovery after the server has gone down. This is access request code point 1 from RFC2865 with the user name/password set to fakeuser/fakepasswd. |
