Universal APs are configured for cloud management by default. If you want to manage
these APs locally, you must specify Local Management when
onboarding the APs in ExtremeCloud IQ.
To onboard your cloud-ready APs for Local Management with ExtremeCloud IQ
Controller, take the
following steps:
Log into your ExtremeCloud IQ account and select
The Welcome dialog
displays.
ExtremeCloud IQ
Welcome Dialog
For on-premise management,
select Deploy your
devices locally.
On the next screen, select
Let‘s Get
Started.
Enter the Universal AP serial
numbers:
Serial numbers are available on
the back of the AP or on the AP box label. In most cases, the invoice provided
by the distributor includes the serial number of the devices fulfilled with the
order. The ExtremeCloud IQ onboarding logic validates the
serial numbers against the model compatibility and manufacturing date to ensure
only compatible devices are onboarded.
See Deploy Universal APs for a list of minimum
serial numbers that are supported by ExtremeCloud IQ
Controller
for specific Universal AP models.
Enhanced
Discovery. Enhanced Discovery can be used to enhance support of onboarding for Local Management (within ExtremeCloud IQ) providing an option to define the list of primary and secondary controllers running ExtremeCloud IQ
Controller For more information, see Enhanced Discovery.
Enhanced Discovery is supported on AP3000 and ExtremeCloud IQ
Controller.
Select Onboard
Devices.
Select Finish.
The APs display on the
ExtremeCloud IQ Device List with the status Onboarded. New
APs display the generic HOSTNAME because they are not yet registered with ExtremeCloud IQ. The AP Hostname automatically updates after the AP is
powered on and connected into ExtremeCloud IQ.
Connect the AP to the
network.
Connect the AP to a switch
through (ETH0/POE+). The AP hostname is recognized after the AP connects. It
starts in the WiNG 7 operating system and
discovers the ExtremeCloud IQ
Controller provided that you have configured the necessary DHCP
and DNS options.
The following are ExtremeCloud IQ
Controller
discovery options:
DHCP
Option
78: Points to SLP DA, which is typically instantiated
within the appliance itself.
Option
43/60: Can point directly to the appliance, but would
require double encoding of code points for Centralized
(01). DHCP Server may not allow overload.
Creating a device group
for each Universal AP model associated with a site.
Associating a
configuration Profile to each device group. The configuration Profile
includes defined networks and operational settings required for
service.
Assigning each AP to the
appropriate device group.
Section contents:
Enhanced Discovery Learn about Enhanced Discovery support for remote deployments. You can configure specific controllers to discover devices in remote locations.
