ExtremeCloud IQ
Controller Default
Pass-Through Rule
Create a RADIUS Pass-Through rule on ExtremeCloud IQ
Controller. This rule
designates that traffic connecting to the Guest network will send and receive all RADIUS
requests from the externally defined Access Control Engine server, not from the ExtremeCloud IQ
Controller that processes
the request. This includes filter-ids that are received as attributes. The ExtremeControl Access Control Engine provides RADIUS authentication and
authorization and policies that are defined in ExtremeCloud IQ Site Engine.
On ExtremeCloud IQ
Controller, go
to Onboard > Rules > Add.
Configure the following
parameters:
Name
Guest
Rule Enabled
Select this option to enable the
new rule.
Location Group
SSID: Guest
Accept Policy
Pass-Thru External RADIUS
Select Save.
Move the rule to the top of the rule set, if it is not already there.
