Wireless devices (APs and SA201 adapters)
discover the IP address of ExtremeCloud IQ
Controller using a sequence of mechanisms that allow
for the possible services available on the enterprise network. The discovery process is
successful when the AP/adapter successfully locates a controller to which it can register.
Ensure that the appropriate services on your enterprise network are prepared to support the
discovery process.
The
following subnets are reserved for internal communications and Docker operations:
172.17.0.0/24
172.31.0.16/28
The ExtremeCloud IQ
Controller user
interface logic prevents adding addresses in these address ranges for VLAN interface
references.
An access point can learn a hostname from a DHCP server. The AP reports either
the discovered hostname, or an internally generated hostname (which is the AP serial number)
to the controller as part of the discovery process.
If ExtremeCloud IQ
Controller does not have a current record of the
AP, the controller applies the reported hostname for use in the Name and Hostname fields
for the AP.
If ExtremeCloud IQ
Controller already has a record for the AP, then
the controller ignores the reported hostname.
If the AP does not report a hostname to
the controller as part of the discovery process, and there is no record of the AP on ExtremeCloud IQ
Controller, then the name
and hostname are generated.
