Configure a Generic Routing Encapsulation (GRE) tunnel topology for a given VLAN and
assign Tunnel Concentrator instances to the VLAN.
Optionally, you can assign rules that manage the volume of multicast and broadcast
traffic that crosses Tunnel Concentrator. For example, you can limit multicast
traffic to a defined set of multicast addresses and broadcast traffic to essential
broadcasts only.
- Log in to ExtremeCloud IQ Controller.
- Go to .
- Configure the following
parameters:
- VLAN Name
- Name of the GRE
- Mode
- Select GRE
for a Generic Routing Encapsulation (GRE) tunnel.
- VLAN ID
- The ID of the VLAN.
This value must be unique.
- Tagged
- Specify if the egress
port traffic is tagged or untagged. Most GRE VLAN topologies must be
tagged. Each concentrator can support only one untagged
topology. Select Tagged to tag the topology.
- Tunnel Concentrators
- List of Tunnel
Concentrators.
Select a concentrator from the list, then select
Add. You can add up to three concentrators to a
single topology. When more than one termination point is added
to the list, failover is supported.
The order of the
termination points is significant. The primary concentrator must
be the first termination point in the list. The AP issues a ping
request to the first termination point. If that request fails,
it pings the second point, and then the third point. With this
organization, you can use the same three concentrators for
multiple VLANs, and by varying the termination point order for
each VLAN, you can balance the traffic load.
It is a best practice
to configure more than one Tunnel Concentrator per VLAN topology for failover. A topology
that uses a single generic (non-encrypted) GRE tunnel, without configured backups, is not
using the available mechanisms to detect if a Tunnel Concentrator is down. Therefore, no AP
alarms, related to the tunnel connectivity, are generated for such a topology.
- Load Balance
- This checkbox is
visible only when the list of concentrators has more than one
element. Check Load
Balance to load balance APs between concentrators.
- (Optional). To configure rules for broadcast and
multicast traffic, select Advanced and configure the following:
- Select Multicast Bridging if
you want to be able to forward multicasts between the wired and wireless
sides of the AP.
- If you enabled multicast bridging and want
to customize a multicast rule, select Add New Rule and
- IP
- Enter the multicast IP address (e.g.,
224.0.0.5) or network address (e.g., 224.0.0.0) that
identifies a range of allowed multicast addresses.
- CIDR
- For a network address, enter the number
of network bits (e.g., 27) to define the network and host
portion of the allowed range. All multicast addresses that
are encompassed by the range are allowed.
- Wireless Replication
- Select this option to allow wireless
replication of multicast packets. By default, this field is
selected.
to assign a system default multicast rule, select Add Predefined Rule,
select the rule, and then select Add.
- Select Block Non-Essential Broadcast
Traffic if you want Tunnel Concentrator to block all
broadcast traffic, except for DHCP and ARP (this is the default
setting). Otherwise, Tunnel Concentrator floods broadcast traffic to all
APs.
- Select Close.
- Select Save.
