ExtremeCloud IQ Configuration
If you selected ExtremeCloud IQ as your management application, complete the tasks in the following task flow on the ExtremeCloud IQ (Classic) interface to provision tunneling using Tunnel Concentrator.
Tunnel Concentrator supports ExtremeCloud IQ (Classic) and does not support ExtremeCloud IQ (New). All references in this guide to "ExtremeCloud IQ" mean "ExtremeCloud IQ (Classic)".
Before you Begin
  • Tunnel Concentrator(s) must be installed already with ExtremeCloud IQ selected as management entity. For details, see Installation.
  • You must have a Network Policy and SSIDs configured on ExtremeCloud IQ already. For help with these configuration elements, see the ExtremeCloud IQ (Classic) User Guide.
Table 1. Tunnel Concentrator Task Flow from ExtremeCloud IQ
ProcedureDescription
1Quick Add Tunnel ConcentratorsOnboard your Tunnel Concentrators to ExtremeCloud IQ.
2Configure Tunnel Concentrator ServiceConfigure a service that uses a single instance of Tunnel Concentrator or a redundant HA pair of instances.
3Configure Tunnel Policy(Optional) If you want Layer 2 roaming, configure a Tunnel Policy that points to your Tunnel Concentrator service.
4Configure User Profile with Tunnel ConcentratorAssign the Tunnel Concentrator service(s) to a User Profile.
5Configure SSIDs with Tunnel Concentrator User ProfileAssign your Tunnel Concentrator User Profile(s) to wireless SSIDs.
6Deploy Network PolicyComplete a delta push to deploy the Network Policy to affected devices.
  • Each Tunnel Concentrator Service can reference up to two Tunnel Concentrator devices.
  • Primary and backup Tunnel Concentrators must belong to the same network policy.
  • For a redundant Tunnel Concentrator, the IP addresses of both the primary and redundant Tunnel Concentrators must belong to the same subnet as the Tunnel IP Address/CIDR.
  • The Gateway IP Address must belong to the same subnet as the Tunnel IP Address/ CIDR.
Alternative Configuration Flow
If you don't want Layer 2 roaming, and aren't configuring a Tunnel Policy, you can use a streamlined configuration where you assign all settings from the Network Policy. See ExtremeCloud IQ (Classic) Configuration Example (Alternative Flow) for a configuration example that uses this approach.
