Use this optional procedure to configure a tunnel policy that points to your Tunnel Concentrator service(s). If you want Layer 2 roaming, you can use the policy to quickly provision Tunnel Concentrator across multiple user profiles in different SSIDs.
The Tunnel Policy is not a mandatory configuration as you can assign a Tunnel Concentrator service to a user profile directly.
Optionally, you can select the
(Add) icon to open a Tunnel Concentrator
service configuration window where you can configure a new service that gets
applied to the corresponding tunnel destination for the tunnel
policy.
Tip
Assign this Tunnel Policy configuration to one or more user profiles to use the Tunnel Destination settings from this configuration in those user profiles.
