Deploy Network Policy
Use this procedure to deploy the updated Network Policy with the Tunnel Concentrator configuration to affected APs and Tunnel Concentrators.
  1. On ExtremeCloud IQ (Classic), go to Configure > Network Policies.
  2. Select the updated policy.
  3. Select 6 Deploy.
  4. Select the devices that you want to update.
    Use the Assigned, Eligible, and Filtered controls to limit the display to specific devices only.
  5. Select Upload.
  6. In the Device Update window, select Update Network Policy and Configuration and select the Delta Configuration Push option.
  7. Select Perform Update.
For additional Network Policy deployment options, see the "Configure Network Policies" chapter of the ExtremeCloud IQ (Classic) User Guide.
