The following table lists recommended versions for the components that make up the Tunnel Concentrator solution. We recommend that you run the latest version for each component.
| Solution Components | Supported Versions |
| Universal Compute Platform (1130C, 2130C, 3150C, or 4120C) | Universal Compute Platform v5.13.01 or later |
| ExtremeCloud IQ |
ExtremeCloud IQ (Classic) v25.08 or later |
| ExtremeCloud IQ Controller | ExtremeCloud IQ Controller v10.18.01 or later |
| Access points |
Tunnel Concentrator is supported on ExtremeCloud IQ (Classic). Universal access points and on IQ Engine access points. See ExtremeCloud IQ (Classic) Release Notes for hardware and OS release information. |
Refer to the following table for information on supported Tunnel Concentrator capacities for each Universal Compute Platform hardware option.
| Installed on | Supported Capacities |
| 1130C |
| 2130C |
| 3150C |
| 4120C |
With ExtremeCloud IQ deployments, take the redundancy configuration into consideration when scaling your deployment. Note the following points:
For ExtremeCloud IQ Controller deployments a Tunnel Concentrator instance can handle up to its maximum capacity, even if that instance is being used by multiple VLANs.
