Management layer
Data layer
The following image provides a high-level of the two stacks for a Tunnel Concentrator instance, along with the internal connections and systems that allow Tunnel Concentrator to connect to external devices, such as an external switch. The data layer can be accessed directly, but access to the management layer is hidden behind an internal NAT reference with access dependent on the underlying Universal Compute Platform routing table.
