Add Static Route
Static Routes define the default route to Universal Compute Platform for legitimate wireless traffic. You must be a system administrator to add a static route.
Static Routes affect the settings for the Default Gateway IP address under Host Attributes. Adding a default static route (0.0.0.0/0) changes the Default Gateway IP address.
To add a static route, take the following steps:
  1. Go to Administration > System > Network Setup.
  2. Under Static Routes select Add New Route.
    The New Static Route dialog displays.
  3. Configure the Static Route Properties. For detailed field descriptions, see Static Route Properties.
  4. Select Save.
