Universal Compute Platform supports a Standalone mode and a full Cluster mode. Standalone mode requires only one defined node, but a cluster can be deployed with multiple nodes in multiples of three (for example, three, six, nine nodes, or more) depending on your resource requirements.
For Cluster Mode, select Standalone or Cluster.
(Clusters only). From the Number of Nodes drop-down, select the number of nodes for the cluster.
(Clusters only). From the Number of Availability Zones drop-down, select the number of zones that you want to deploy.
Enter the ICC IP Address for each node.
Select Next.
If you are deploying multiple availability zones, make sure that each ICC IP address falls under the zone where you want to deploy that node.What to do Next
