Use this procedure to configure Link Aggregation Group (LAG) interfaces on Universal
Compute Platform.
Make sure to configure LAG on the
switch that connects to the LAG ports. Otherwise, the LAG connection fails.
Go to .
If
you want to aggregate any data ports, under L2 Ports, assign data ports
to each LAG interface that you want to configure:
For LAG1, select each
data port from the Member Ports of LAG column
that you want to add to this LAG.
For LAG2, select each
Select Save and then select
OK.
The LAG interface inherits
the VLAN assignments automatically from newly added port
members.
If
you want to aggregate the ICC ports, under ICC Interfaces, select
LAG.
Complete the LAG interface
configuration for each new LAG interface:
Under Interfaces, select the new LAG interface.
Configure the interface
settings. For more information, see Create New Interface Settings.
Select Save.
