Configure Interface Settings for Engine Application
Use this procedure to configure the final application interface settings immediately after you deploy an application. You can use these settings to assign a VRRP IP alias to the application (which is required for some applications).
  • Refer to the documentation for your engine application for application-specific requirements. Configuration requirements can vary per application.
  • For more information on the fields that appear on this page, see Engine Application Settings.
  1. Go to the application interface settings page for your application.
    The page launches automatically after you select the Deploy option for a newly installed application. Otherwise, go to Engines > Installation and then select the link for the engine instance.
  2. Copy or record the Locking ID (Serial Number). Most applications require you to provide this value during license activation.
  3. Optional. If your engine application requires you to configure a VRRP IP alias:
    1. Select the Network Service Configuration tab.
    2. From the Assigned Virtual IP Address field, select a VRRP address that you assigned previously on a data port.
    3. Select Save.
  4. Optional. To launch the application user interface, select the Instance Web Interface link.
