Generate CSR
Use this procedure to complete a Certificate Signing Request (CSR) that you can use to generate a CA certificate that you can install on a Universal Compute Platform interface. You can issue a CSR from the Certificates window.
  1. Go to Administration > System > Network Setup.
  2. Select an interface and select Certificates.
  3. In the Certificates window, select Generate CSR.
  4. Complete the fields in the Generate Certificate Signing Request window.
    Table 1. Generate Certificate Signing Request Fields
    Field Description
    Country Name Enter the two-letter ISO abbreviation for the country.
    State or Province Enter the name of the state or province.
    Locality Name Enter the locality name (for example, the city or town).
    Organization Name Enter the name of the organization.
    Organizational Unit Enter the name of the unit within the organization.
    Common Name Enter the certificate common name (e.g., FQDN or IP address).
    Email Address Enter an email address for notification purposes.
    Key Size Select the key size in bits. Supported sizes are 1024 or 2048.
  5. Select Save.
Generate and download the CSR request that you can present to a public certificate authority. Once you've received a CA certificate back from the certificate authority, return to Update Certificates to install the certificate on an interface.
