Universal Compute Platform v5.15.01 User Guide
Administration
System Configuration
Network Setup
> Add Interface
Extreme Networks, Inc. September 28, 2026
Abstract
Preface
Welcome to Universal Compute Platform
Navigating the User Interface
Dashboard
Deployment Health Dashboard
System Health Dashboard
Nodes Dashboard
Availability Zones Dashboard
Pods List
VMI List
Services List
Volumes List
Cluster Settings
Availability Zones
Cluster Configuration
Select the Deployment Type
Configure Cluster Mode
Configure Pod Network Information
Add Nodes
Replace a Node
Engines
Engine Installation Options
ExtremeCloud Edge - Managed Orchestration
Run Readiness Assessment
Install ExtremeCloud IQ Engine
Network Service Configuration
Account Registration
ExtremeCloud Edge - Self-Orchestration
Download Docker Application Image
Upload Docker Application Image
Install Engine Application
Deploy Application Image
Configure Interface Settings for Engine Application
Engine Application Settings
Engine Upgrades
Upgrade an Application (Self-Orchestrated)
Tools
Logs
Diagnostics
Administration
Manage User Accounts
Account Settings
Configuration
Run a Backup
Restore Backup File
Schedule a Backup
Configure SNMP
SNMP Settings
System Logging
Maintenance
Network Setup
Add Interface
Create New Interface Settings
LAG Interfaces
Configure LAG Ports
Add Static Route
Static Route Properties
Certificates
Update Certificates
Generate CSR
Network Time
Cloud Visibility
Add Web Proxy Server
Upgrade the Universal Compute Platform
Upgrade Universal Compute Platform Task Flow
Upload Software Image
Copy Image to All Nodes
Upgrade Nodes
Schedule an Upgrade
Kubernetes Upgrade
Upgrade Logs
System Information
Utilities
Add Interface
Use this procedure to configure a new interface on Universal Compute Platform.
For detailed help with the fields and their configuration options, see
Go to
Administration
System
Network Setup
Under
, select
Add New Interface
Assign a
Name
and
IP Address
to the interface.
Assign any additional settings that you want.
Optional. To add a VRRP address on this interface, select
Add
and then configure VRRP settings.
Select
Save
