            Use this screen to define default firewall rules. These firewalls are applied if no
                role-specific firewall rules have been specified.
            To add default firewall rules:
                Select the Default Firewall Rules tab.
                Specify an IP Inbound or
                        IP
                        Outbound firewall rule by selecting a rule from the drop-down
                    menu and use the spinner control to assign the rule Precedence.
Rules with lower precedence are
                    always applied first to packets. Select the + Add Row button
                    or Delete
                    icon as needed to add or remove IP firewall rules. If no IP Inbound or Outbound
                    firewall ACL exist create the IP firewall ACL and use here.
                Specify an MAC Inbound or
                        MAC
                    or Delete
                    icon as needed to add or remove MAC firewall rules. If no MAC Inbound or
                    Outbound firewall ACL exist create the MAC firewall ACL and use here.
                Select OK to save your changes.
Select Reset to revert to the last saved
                    configuration.
