The ability to allow or deny access point connectivity by client MAC address ensures malicious or unwanted clients are unable to bypass the access point's security filters. Firewall rules can be created to support one of the three actions listed below that match the rule's criteria:
To view the access point's MAC Firewall Rules:
| Precedence |
                                  Displays the precedence value, which are applied to packets. The rules within an ACL list are based on their precedence values. Every rule has a unique precedence value between 1 and 5000. You cannot add two rules with the same precedence value.  |
| Friendly String |
                                  This string provides more information as to the contents of the rule. This is for information purposes only.  |
| Hit Count |
                                  Displays the number of times each WLAN ACL has been triggered.  |
