                               Protocol  |
                               Select the protocol for device firmware file management and transfer. Available options include: tftp ftp sftp http cf  |
                               Port  |
                               Designate the port for transferring the firmware files used in the upgrade operation. Enter the port number directly or use the spinner control.  |
                               Host  |
                               Specify a numerical IP address or textual Hostname of the resource used to transfer files to the devices designated for a firmware update.  |
                               Path / File  |
                               Define the path to the file on the file repository resource. Enter the complete relative path to the file.  |
The firmware image is loaded to the flash/upgrade directory (not the flash/cache directory). If the NOC pushes the image, then it is loaded to flash/cache/upgrade.
