The feature let you know the “description” per EFA port-channel which further gets configured on the SLX port-channel. The default value of PO “description” is “EFA Port-channel <efa-po-name>”.
You can provide the PO “description” during PO create and PO update operations.
efa tenant po create --name <po-name> --tenant <tenant-name> --description <po-description>
--speed <100Mbps|1Gbps|10Gbps|25Gbps|40Gbps|100Gbps> --negotiation <active|passive|static>
--port <list-of-po-members> --min-link-count <min-link-count> --number <po-number> --lacp-timeout <short|long>
efa tenant po update --name <po-name> --tenant <tenant-name>
--operation <port-add|port-delete|lacp-timeout|description|min-link-count>
--port <list-of-po-members> --lacp-timeout string <short|long> --min-link-count <min-link-count>
efa tenant po create --name ten1po1 --tenant ten1 --port 10.20.246.15[0/1],10.20.246.16[0/1] --speed 10Gbps --negotiation active --description tenant1po1 efa tenant po create --name ten1po2 --tenant ten1 --port 10.20.246.15[0/2],10.20.246.16[0/2] --speed 10Gbps --negotiation active efa tenant po update --name ten1po1 --tenant ten1 --operation description --description tenat1po1changed
Tenant : ten1
Description : tenat1po1changed
Speed : 10Gbps
Negotiation : active
Min Link Count : 1
Lacp Timeout : long
Ports : 10.20.246.15[0/1]
: 10.20.246.16[0/1]
State : po-created
Dev State : provisioned
App State : cfg-in-sync
Tenant : ten1
Description : EFA Port-channel ten1po2
Speed : 10Gbps
Min Link Count : 1
Lacp Timeout : long
Ports : 10.20.246.15[0/2]
: 10.20.246.16[0/2]
State : po-created
Rack1-Device1# show running- config interface Port-channel interface Port-channel 1 description tenat1po1changed no shutdown ! interface Port-channel 2 description EFA Port-channel ten1po2 no shutdown ! Rack1-Device1# |
Rack1-Device2# show running- config interface Port-channel interface Port-channel 1 description tenat1po1changed no shutdown ! interface Port-channel 2 description EFA Port-channel ten1po2 no shutdown ! Rack1-Device2# |
