The following table describes information added to this guide for the Extreme Fabric Automation 2.4.0 software release.
| Feature | Description | Link |
Delete operations cause discrepancies during admin partial success |
Added the reason for not attempting the Delete-related configurations (de-configurations) for the "admin down" device. Updated tips and considerations on retrying the same CLI/REST operation after the “admin down” devices transition to “admin up” state and on blocking the tenant reconciliation API by EFA. |
Centralized Routing Support |
A new topic is added to describe the centralized routing configuration. | Centralized Routing |
| Event Synchronization and Missing Event Handling | New topic that describes workaround for the missing events. | Event Synchronization and Missing Event Handling |
| Improve backup-restore and supportsave | Added a note on Logs related to backup, restore, and supportsave operations. | EFA System Backup and Restoration |
| Notify on device certificate expiration | Updated the topic inventory certificates expiration date of managed devices. | EFA Certificate Management |
Multiple Management IP Network |
New topic on accessing EFA from multiple servers, which are on different IP subnets in different subnets. You can create multiple IP subnets through EFA for day 1 configurations. | Multiple Management IP Network |
| SNMP Traps Publication | New topic describes EFA registration (during device registration) as a trap recipient to be able to receive traps from the devices. | |
| New port for third-party certificates | Port 443 (present in previous versions) is for secure installation of EFA; port 8078 is for monitoring service of EFA. | EFA Certificate Management |
| System restore | The restore process now shows you the backup tar files you can choose from. | Back up and Restore the EFA System |
| EFA system health | A new topic describes methods for verifying system health. | Verifying EFA System Health |
| Return Material Authorization | The process has a revised workflow. | |
| Firmware upgrades | These processes have revised workflows. | Hitless Firmware Upgrade |
For more information about this release, see the Extreme Fabric Automation Release Notes, 2.4.0 .
