You can use the EFA CLI to add and delete management sub-interfaces.
For more information about the following commands, see the Extreme Fabric Automation Command Reference, 2.4.0 .
efa mgmt subinterface create --name <name> --ip-address <IP Subnet> --vlan-id <VLAN>
If a management network with the same name exists, the users are informed about it and this operation fails.
The changes made by this operation span across three different components:
If any of the operations to the component fails, it is marked as a failed operation and the configurations return to the previous state.
efa mgmt subinterface delete --name <name>
If a management network with the name exists, it is deleted. Otherwise, the correct response is provided in the command output.
$ efa mgmt subinterface? Management subinterface commands Usage: efa mgmt subinterface [command] Available Commands: create Create sub-interface (sub-interface) delete Delete sub-interface (sub-interface) show List of sub-interfaces (sub-interfaces) Flags: -h, --help help for sub-interface Use "efa mgmt subinterface [command] --help" for more information about a command.
$ efa mgmt subinterface create -h
Create management subinterface (sub-interface)
Usage:
  efa mgmt subinterface create [flags]
Flags:
      --name string         Name of the sub-interface
      --vlan-id int         VLAN Id of sub-interface
      --ip-address string   IP Address of sub-interface including subnet mask.
                            Example: 10.24.80.150/24
  -h, --help                help for create
        $ efa subinterface delete -h
Delete management subinterface (sub-interface)
Usage:
  efa mgmt subinterface delete [flags]
Flags:
  -h, --help          help for delete
        $ efa mgmt subinterface show -h
List of management sub-interfaces (sub-interfaces)
Usage:
  efa mgmt subinterface show [flags]
 Flags:
   -h, --help          help for show
        $ efa mgmt subinterface create --name server1 --vlan-id 20 --ip-address
          20.20.20.2/24
Subinterface server1 created successfully
        $ efa mgmt subinterface delete --name server1 Subinterface server1 deleted successfully
$ efa mgmt subinterface show +---------------+------------------+------+---------------+ | Sub-Interface | Parent Interface | Vlan | IP Subnet | +---------------+------------------+------+---------------+ | server1 | eth0 | 20 | 20.20.20.2/24 | +---------------+------------------+------+---------------+ | server2 | eth0 | 50 | 50.50.50.2/24 | +---------------+------------------+------+---------------+ Management Subinterfaces Details
$ efa mgmt subinterface show --name server1 +---------------+------------------+------+---------------+ | Sub-Interface | Parent Interface | Vlan | IP Subnet | +---------------+------------------+------+---------------+ | server1 | eth0 | 20 | 20.20.20.2/24 | +---------------+------------------+------+---------------+ Management Subinterface Details
