You can use the EFA command line to replace a faulty device with a new device and
maintain the configuration of the old device.
Prerequisites:
- Ensure that periodic configuration backup is enabled on all devices that may
need RMA. This prerequisite ensures that you have the latest configuration file
to be used for recovery.
- Ensure that maintenance mode is enabled upon reboot on all devices.
This procedure describes how to replace a faulty device as part of the Return
Material Authorization (RMA) process. For more information, see Return Material Authorization.
Obtain the configuration backup
of the old device.
# efa inventory config-backup execute --ip <ip-addr>
This step generates a configuration backup ID that you use in step
5.
Replace the faulty device with
the new device.
Ensure that the ports of the new device are administratively up and
online.
Configure the new device with the same management IP address and credentials as
the old device.
Start the RMA process.
# efa inventory rma execute --ip <ip-addr> --config-backup-id <id>
As a best practice, run the command with the
--config-backup-id
<id>
option so that the configuration is properly restored.
If you run the command without the backup ID, you will need to manually
update the configuration on the new device.
View the RMA history and
detail.
# efa inventory rma history -–ip <ip-addr>
# efa inventory rma detail –uuid <uuid>
View the drift reconcile history
and detail.
# efa inventory drift-reconcile history -–device-ip <ip-addr>
# efa inventory drift-reconcile detail –-uuid <uuid>
Install the HTTPS or OAuth2 certificate on the new device.
# efa certificates device install --ips <device-ip-addr> --certType [https|token]
- Optional:
Delete the RMA record.
# efa inventory rma delete -–ip <ip-addr>
- Optional:
Manually start the drift
reconcile process if the RMA process fails during the drift reconcile stage.
# efa inventory drift-reconcile execute --ip <ip-addr> –-reconcile
