VRF: Graceful Restart
The Tenant service configures graceful
restart under each tenant VRF ipv4/v6 unicast address-family.
You can enable graceful restart per tenant VRF during VRF creation and VRF update operations.
EFA provisions the user input graceful restart on the switches during the instantiation and
update of VRF on the switches.
- VRF is instantiated on the switches
during a user-triggered L3 EPG create or L2 EPG transition to L3 EPG, based on the
endpoints present in the EPG.
- VRF is updated on the switches during a
user-triggered VRF update operation, based on the endpoints present in the EPGs, using
this VRF.
Currently, the enable or disable value of graceful restart depends on the per-user VRF
configuration.
- By default, graceful restart is disabled. The default value of graceful restart is the
switch default.
- EFA versions earlier than v2.4 have graceful restart enabled by default.
- An upgrade from a version earlier than v2.4 to v2.4 will retain the graceful restart as
enabled for all the VRFs that were configured before the upgrade.
Switch Config
Rack1-Device1#sh run router bgp
router bgp
local-as 4200000000!
address-family ipv4/v6 unicast vrf vrf1
redistribute connected
graceful-restart
address-family ipv4 unicast vrf vrf10
Rack1-Device2#sh run router bgp
router bgp
graceful-restart
