The EPG Network Property Description allows you to configure “description” per EFA tenant ctag which gets configured on the SLX as VLAN/BD description.
The default value of “description” is as below:
| Network Type | Description |
| L2 Extension | Tenant L2 Extended VLAN/BD |
| L3 Extension | Tenant L3 Extended VLAN/BD |
| L3 Handoff | Tenant L3 Hand-off VLAN/BD |
| L3 Extension EVPN IRB | Tenant L3 Extended IRB BD |
You can provide the EPG network “description” during EPG create and EPG update (ctag-range-add) operations.
During the upgrade from EFA 2.3.2 to EFA 2.4.0, for all the EPG networks, the default “description” is determined and the app-state is set to “cfg-refreshed” so that the user triggers DRC (in EFA 2.4.0) to push the derived network “description” on to the SLX.
efa tenant epg create --name <epg-name> --tenant string <tenant-name> --port <list-of-phy> --po <list-of-po>
--switchport-mode <access |trunk | trunk-no-default-native>
--ctag-range string <ctag-range> --ctag-description <ctag:description>
efa tenant epg update --name <epg-name> --tenant <tenant-name> --operation <ctag-range-add>
--ctag-range <ctag-range> --ctag-description <ctag:description>
efa tenant show +----------+---------+------------+-------------+-------------+-----------+-----------+-----------------------+ | Name | Type | VLAN Range | L2VNI Range | L3VNI Range | VRF Count | Enable BD | Ports | +----------+---------+------------+-------------+-------------+-----------+-----------+-----------------------+ | bdTen1 | private | 21-30 | | | 10 | true | 10.20.246.15[0/11-20] | | | | | | | | | 10.20.246.16[0/11-20] | +----------+---------+------------+-------------+-------------+-----------+-----------+-----------------------+ | vlanTen1 | private | 11-20 | | | 10 | false | 10.20.246.16[0/1-10] | | | | | | | | | 10.20.246.15[0/1-10] | +----------+---------+------------+-------------+-------------+-----------+-----------+-----------------------+ efa tenant vrf create –name ten1vrf1 –tenant vlanTen1 efa tenant vrf create –name ten2vrf2 –tenant bdTen1
VLAN Based L2 Extension EPG
efa tenant epg create --name ten1epg1 --tenant vlanTen1 --port 10.20.246.15[0/1],10.20.246.16[0/1] --switchport-mode trunk --ctag-range 11-12 --ctag-description 12:Ten1VLANNW1
VLAN Based L3 Extension EPG:
efa tenant epg create --name ten1epg2 --tenant vlanTen1 --port 10.20.246.15[0/1],10.20.246.16[0/1] --switchport-mode trunk --ctag-range 13-14 --ctag-description 14:Ten1VLANNW2 --anycast-ip 13:10.0.13.1/24 --anycast-ip 14:10.0.14.1/24 --vrf ten1vrf1
efa tenant epg create --name ten1epg3 --tenant vlanTen1 --type l3-hand-off --port 10.20.246.15[0/1],10.20.246.16[0/1] --switchport-mode trunk --ctag-range 15-16 --ctag-description 16:Ten1VLANNW3
efa tenant epg create --name ten2epg1 --tenant bdTen1 --port 10.20.246.15[0/11],10.20.246.16[0/11] --switchport-mode trunk --ctag-range 21-22 --ctag-description 22:Ten2BDNW1
BD Based L3 Extension EPG
efa tenant epg create --name ten2epg2 --tenant bdTen1 --port 10.20.246.15[0/11],10.20.246.16[0/11] --switchport-mode trunk --ctag-range 23-24 --ctag-description 24:Ten2BDNW2 --anycast-ip 23:10.0.23.1/24 --anycast-ip 24:10.0.24.1/24 --vrf ten2vrf
efa tenant epg show --detail
Rack1-Device1# show running- config bridge-domain bridge-omain 1 p2mp description Tenant L2 Extended BD pw-profile default logical-interface ethernet 0/11.21 bpdu-drop-enable local-switching ! bridge-domain 2 p2mp description Ten2BDNW1 pw-profile default logical-interface ethernet 0/11.22 bpdu-drop-enable local-switching ! bridge-domain 3 p2mp description Tenant L3 Extended BD pw-profile Tenant-profile router-interface Ve 4099 ! logical-interface ethernet 0/11.23 bpdu-drop-enable local-switching suppress-arp ! bridge-domain 4 p2mp description Ten2BDNW2 pw-profile Tenant-profile router-interface Ve 4100 ! logical-interface ethernet 0/11.24 bpdu-drop-enable local-switching suppress-arp ! bridge-domain 4093 p2mp description Tenant L3 Extended IRB BD pw-profile Tenant-profile router-interface Ve 8189 ! bpdu-drop-enable local-switching ! bridge-domain 4094 p2mp description Tenant L3 Extended IRB BD pw-profile Tenant-profile router-interface Ve 8190 ! bpdu-drop-enable local-switching ! |
Rack1-Device2# show running- config bridge-domain bridge-domain 1 p2mp description Tenant L2 Extended BD pw-profile default logical-interface ethernet 0/11.21 bpdu-drop-enable local-switching ! bridge-domain 2 p2mp description Ten2BDNW1 pw-profile default logical-interface ethernet 0/11.22 bpdu-drop-enable local-switching ! bridge-domain 3 p2mp description Tenant L3 Extended BD pw-profile Tenant-profile router-interface Ve 4099 ! logical-interface ethernet 0/11.23 bpdu-drop-enable local-switching suppress-arp ! bridge-domain 4 p2mp description Ten2BDNW2 pw-profile Tenant-profile router-interface Ve 4100 ! logical-interface ethernet 0/11.24 bpdu-drop-enable local-switching suppress-arp ! bridge-domain 4093 p2mp description Tenant L3 Extended IRB BD pw-profile Tenant-profile router-interface Ve 8189 ! bpdu-drop-enable local-switching ! bridge-domain 4094 p2mp description Tenant L3 Extended IRB BD pw-profile Tenant-profile router-interface Ve 8190 ! bpdu-drop-enable local-switching ! |
Rack1-Device1#show running-config vlan vlan 11 description Tenant L2 Extended VLAN ! vlan 12 description Ten1VLANNW1 ! vlan 13 router-interface Ve 13 suppress-arp description Tenant L3 Extended VLAN ! vlan 14 router-interface Ve 14 suppress-arp description Ten1VLANNW2 ! vlan 15 description Tenant L3 Hand-off VLAN ! vlan 16 description Ten1VLANNW3 ! Rack1-Device1# |
Rack1-Device2# show running-config vlan vlan 11 description Tenant L2 Extended VLAN ! vlan 12 description Ten1VLANNW1 ! vlan 13 router-interface Ve 13 suppress-arp description Tenant L3 Extended VLAN ! vlan 14 router-interface Ve 14 suppress-arp description Ten1VLANNW2 ! vlan 15 description Tenant L3 Hand-off VLAN ! vlan 16 description Ten1VLANNW3 ! Rack1-Device2# |
