VRF: Redistribute
EFA allows provisioning of redistribute attribute per tenant VRF during VRF create and VRF update operations.
VRF is updated on the switches during the user triggered VRF update operation based on the endpoints present in the EPGs using the VRF.
Default value of redistribute is connected.
Choosing specific devices for redistribute provisioning is not allowed.
EFA provisioning
VRF Create
# efa tenant vrf create --name <vrf-name> --tenant <tenant-name> --redistribute <list>
VRF Update
# efa tenant vrf update --name <vrf-name> --tenant <tenant-name> --operation <redistribute-add|redistribute-delete> --redistribute <static | connected>
VRF Update
# efa tenant vrf create --name vrf1 --tenant tenant1 --redistribute static
# efa tenant vrf create –name vrf10 –tenant tenant1
# efa tenant epg create --name ten1epg1 --tenant tenant1 --port10.24.80.134[0/11],10.24.80.135[0/11] --switchport-mode trunk –ctag-range 11 --vrf vrf1 –-anycast-ip 11:10.10.11.1/24
# efa tenant epg create --name ten1epg2 --tenant tenant1 --port10.24.80.134[0/12],10.24.80.135[0/12] --switchport-mode trunk -–ctag-range 12 --vrf vrf10 -–anycast-ip 12:10.10.12.1/24
# efa tenant vrf update -–name vrf10 –tenant tenant1 --operation redistribute-add --redistribute static
Device1# sh run router bgp
router bgp
local-as 4200000000
address-family ipv4unicast vrf vrf1
redistribute static
address-family ipv4unicast vrf vrf10
redistribute connected
redistribute static
Device2# sh run router bgp
router bgp
local-as 4200000000
redistribute static
redistribute static
address-family ipv6unicast vrf vrf1
redistribute static
!address-family ipv6unicast vrf vrf10
redistribute static
