Configure route map attribute
To enable external connectivity, configure the route map attribute when you create or update BGP peer.
For information about commands and supported parameters to configure route map attribute, see Extreme Fabric Automation Command Reference, 2.6.0 .
  1. Run the following command to configure route map when you create BGP peer:
    efa tenant service bgp peer create --name <bgp-peer-name> --tenant <tenant-name>
               --ipv4-uc-nbr <device-ip,vrf-name:neighbor-ip,remote-asn>
               --ipv4-uc-nbr-bfd <device-ip,vrf-name:neighbor-ip,true|false>
               --ipv4-uc-nbr-route-map-in <device-ip,vrf-name:neighbor-ip,route-map-name>
               --ipv4-uc-nbr-route-map-out <device-ip,vrf-name:neighbor-ip,route-map-name>
  2. Run the following command to configure route map when you update BGP peer:
    efa tenant service bgp peer update --name <bgp-peer-name> --tenant <tenant-name>
               --operation peer-add
    efa tenant service bgp peer update --name ten1bgppeer1 --tenant ten1
                --ipv4-uc-nbr 10.20.246.15,ten1vrf1:10.20.30.50,50000
                --ipv4-uc-nbr-bfd 10.20.246.15,ten1vrf1:10.20.30.50,true
                --ipv4-uc-nbr-route-map 10.20.246.15,ten1vrf1:10.20.30.50,rmap2,in
                --ipv4-uc-nbr 10.20.246.16,ten1vrf1:10.20.30.50,50000
                --ipv4-uc-nbr-bfd 10.20.246.16,ten1vrf1:10.20.30.50,true
                --ipv4-uc-nbr-route-map 10.20.246.16,ten1vrf1:10.20.30.50,rmap2,out
    efa tenant service bgp peer show --detail
    Tenant           : tenant11
    State            : bgp-peer-created
    Description      :
    Static Peer
            Device IP                   : 10.20.246.23
            VRF                         : v1
            AFI                         : ipv4
            SAFI                        : unicast
            Remote IP                   : 10.40.40.252
            Remote ASN                  : 6500
            Next Hop Self               : false
            Update Source IP            :
            BFD Enabled                 : true
            BFD Interval                : 0
            BFD Rx                      : 0
            BFD Multiplier              : 0
            MD5 Password                : $9$MCgKGaNt6OASX68/7TC6Lw==
            Remove Private AS           : false
            Default Originate           : false
            Default Originate Route Map :
            Prefix List In              :
            Prefix List Out             :
            Route Map In                : tt
            Route Map Out               : rmap1
            Dev State                   : provisioned
            App State                   : cfg-in-sync
            VRF                         : v1
            AFI                         : ipv4
            SAFI                        : unicast
            Remote IP                   : fd40:4040:4040:1::fe
            Remote ASN                  : 6500
            Update Source IP            :
            BFD Enabled                 : true
            BFD Interval                : 0
            BFD Rx                      : 0
            BFD Multiplier              : 0
            Prefix List In              :
            Prefix List Out             :
            Route Map In                : rmap1
            Route Map Out               :
    Dynamic Peer
            0 Records
  3. Verify the switch configuration on the SLX device.
    Rack1-Device1# show running-config router bgp
    router bgp
     local-as 4200000000
     capability as4-enable
     fast-external-fallover
     neighbor 10.20.20.4 remote-as 4200000000
     neighbor 10.20.20.4 next-hop-self
     address-family ipv4 unicast
      network 172.31.254.46/32
      network 172.31.254.123/32
      maximum-paths 8
      graceful-restart
     address-family ipv4 unicast vrf ten1vrf1
      redistribute connected
      neighbor 10.20.30.40 remote-as 50000
      neighbor 10.20.30.40 route-map in rmap1
      neighbor 10.20.30.40 bfd
      neighbor 10.20.30.50 remote-as 50000
      neighbor 10.20.30.50 route-map in rmap2
      neighbor 10.20.30.50 bfd
      maximum-paths 8
      maximum-paths 8
     address-family l2vpn evpn
      graceful-restart
    Rack1-Device2# show running-config router bgp
    router bgp
     local-as 4200000000
     neighbor 10.20.20.5 remote-as 4200000000
     neighbor 10.20.20.5 next-hop-self
      network 172.31.254.176/32
      maximum-paths 8
      graceful-restart
      neighbor 10.20.30.40 route-map out rmap1
      neighbor 10.20.30.50 route-map out rmap2
      maximum-paths 8
      maximum-paths 8
      graceful-restart
