The following table describes information added to this guide for the Extreme Fabric Automation 2.6.0 software release.
| Feature | Description | Link |
| Non-Clos Topology: Dynamic ICL | Describes procedure to configure dynamic Inter-Chassis Link (ICL) in small data centers. | Dynamic ICL in small data center |
| IP prefix list and route map features | Describes procedure to configure IP prefix list and route map. | Policy Services Provisioning Overview |
| IP prefix list and route map features | Update the topic with Policy Service introduction. | EFA Microservices |
| IP prefix list and route map features | Updated the service list with Policy Service. | REST API Documentation for EFA |
| BGP Peer: IP prefix list and route map | Describes procedure to configure route map attributes. | Configure route map attribute |
| VRF: Advertise Address VRF: Advertise Static-Network VRF: Advertise Aggregate Address |
Decribes procedure to configure Advertise Network, Static- Network and Aggregate Address on Tenant VRF. | Configure Advertise Network and Static-Network on Tenant VRF |
| BGP Peer/Peer-Group: remove-private-as and default-originate | Describes procedure to configure remove-private-as and default-originate on BGP Peer and Peer- Group. | Configure remove-private-as on BGP Peer Configure remove-private-as on BGP Peer Group Configure default-originate to advertise default route on BGP Peer |
| 5-stage Clos Solution Validation | Updated with 5-stage Clos fabric topology diagram. | Configure a 5-Stage Clos Fabric |
| IP Pprefix list and route map features | Updated the topic with Drift and Reconcile (DRC), Idempotency for IP prefix list and route map configurations. | Network Elements |
| Support to configure BGP dynamic listen-limit value to '1024' from EFA | Updated the topic with the BGP dynamic listen-limit value. | Configure Listen Limit on BGP Dynamic Peer |
| EFA login to the switch with different user names triggering as a security violation on the switch | Updated the topic with a step to install the certificates on devices . | Back up and Restore the EFA System |
| Multi Node: VIP hostname change failed to change log server on the device post completion | Updated the topic with a note. | Change the Host Name or IP Address |
