efa policy prefix-list create ?
Flags:
--type string Type of prefix-list. Valid types are ipv4
--name string Name of Prefix list
--rule stringArray Rule in format seq[seq-num],action[permit/deny],prefix[IPv4 prefix],ge[prefix-len],le[prefix-len]. Example: seq[5],action[permit],prefix[10.0.0.0/8],ge[10],le[24]
Use the ge and le keywords to specify the range of the prefix length to be matched. Exact match is assumed when neither ge nor le is specified.Following is an example of IPv4 prefix list create:
efa policy prefix-list create –-name prefix_v4 –-type ipv4 –-rule seq[5],action[permit],prefix[10.0.0.0/8],ge[16]
efa policy prefix-list update ?
Flags:
--operation string Valid options are add-rule, remove-rule, add-device, remove-device
--ip string Comma separated range of device IP addresses. Example: 1.1.1.1-3,1.1.1.2,2.2.2.2
Following is an example of IPv4 prefix list update:
Add device: This example configures prefix list on the devices.
efa policy prefix-list update –-name prefix_v4 –-type ipv4 –-operation add-device --ip 10.20.246.10-11
Delete device: This example removes prefix list from the devices.
efa policy prefix-list update –-name prefix_v4 –-type ipv4 –-operation remove-device --ip 10.20.246.10-11
Add rule: This example adds rule to the already created prefix list.
efa policy prefix-list update –-name prefix_v4 –-type ipv4 –-operation add-rule –-rule seq[5],action[permit],prefix[10.0.0.0/8],ge[16]
Delete rule: This example removes rule from the existing prefix list.
efa policy prefix-list update –-name prefix_v4 –-type ipv4 –-operation remove-rule –-rule seq[5],action[permit],prefix[10.0.0.0/8],ge[16]
SLX# show running-config ip prefix-list ip prefix-list prefix_v4 seq 5 permit 10.0.0.0/8 ge 16
efa policy prefix-list list ?
Flags:
Following is an example of IPv4 prefix list show:
efa policy prefix-list list –-type ipv4 –-ip 10.20.246.10-11 Name: prefix_v4 +------+---------+--------+------------+----+----+--------------+-------------+ | Type | Seq num | Action | Prefix | Ge | Le | DeviceIP | AppState | +------+---------+--------+------------+----+----+--------------+-------------+ | ipv4 | 5 | permit | 10.0.0.0/8 | 16 | | 10.20.246.10 | cfg-in-sync | +------+---------+--------+------------+----+----+---------------+------------+ | ipv4 | 5 | permit | 10.0.0.0/8 | 16 | | 10.20.246.11 | cfg-in-sync | +------+---------+--------+------------+----+----+--------------+-------------+
This step deletes the prefix list on all devices and EFA.
efa policy prefix-list delete ?
Flags:
Following example deletes an IPv4 prefix list with name prefix_v4:
efa policy prefix-list delete –-type ipv4 –-name prefix_v4
For more information about commands and supported parameters, see Extreme Fabric Automation Command Reference, 2.6.0 .
