Dynamic ICL in the non-Clos (small data center) fabric contains the following configuration changes:
Fabric settings CLI does not contain MCT ports and L3 backup port options.
There is no distinction between small data center and Clos MCT ports or LD-MCT ports in the backend. They do not have static confirguration options and are identified by LLDP.
EFA running config does not have any references to the MCT ports.
Dynamic ICL configuration maintains backward compatibility for upgrade and downgrade operations for EFA.
