In the current ISW-Series design, one
device supports a three-ring index, including Ring & Chain (single ring, dual ring,
coupling, dual-homing, chain, and balancing-chain.)
When setting up a RingV2 configuration, follow these guidelines:
Enable single ring
before configuring coupling or dual homing.
When single ring, coupling, or
dual homing is enabled, any chain or balancing chain configuration is
inactive.
When chain or balancing chain
is enabled, any configurations for single-ring, coupling, or dual homing are
inactive.
Dual ring topologies can be
single ring, chain, or balancing chain.
Disable RSTP on all ring
ports by navigating to ConfigurationSpanning TreeCIST ports.
