IEEE 802.1x derives keys which can be used to provide per-packet authentication, integrity and confidentially. Typically use along with well-known key derivation algorithms (e.g., TLS, SRP, MD5-Challenge, etc.). The ISW-Series supports 802.1x authentication function per port (port1~port10). You should enable 802.1x function of the system, and choose ports and type you want to apply. If you enable 802.1x authentication control for an Ethernet port, it should be authenticated before using any service from the network.
