Supplicant‘s NIC Setting
After setting this function in NIC, supplicant should enter a correct pair of account and password in order to use this Ethernet port service from the ISW.
  1. Configure a static IP address 20.20.20.10 and net mask 255.255.255.0 for supplicant.
    (If there is a DHCP server to assign IP address for supplicant, this step can be ignored.)
  2. Select the IEEE802.1x Authentication Enable check box, and then set EAP type to MD5-Challenge.
