Regulatory and Compliance Information
Federal Communications Commission (FCC) Notice
This device complies with Part 15 of the FCC rules. Operation is subject to the following two conditions: (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation.
This equipment has been tested and found to comply with the limits for a class A digital device, pursuant to Part 15 of the FCC rules. These limits are designed to provide reasonable protection against harmful interference when the equipment is operated in a commercial environment. This equipment uses, generates, and can radiate radio frequency energy and if not installed in accordance with the operator‘s manual, may cause harmful interference to radio communications. Operation of this equipment in a residential area is likely to cause interference in which case the user will be required to correct the interference at his own expense.
Warning
Warning
Changes or modifications made to this device which are not expressly approved by the party responsible for compliance could void the user‘s authority to operate the equipment.
Industry Canada Notice CAN ICES-3 (A)/NMB-3(A)
This digital apparatus does not exceed the class A limits for radio noise emissions from digital apparatus set out in the Radio Interference Regulations of the Canadian Department of Communications.
Le present appareil numerique n‘emet pas de bruits radioelectriques depassant les limites applicables aux appareils numeriques de la class A prescrites dans le Reglement sur le brouillage radioelectrique edicte par le ministere des Communications du Canada.
Product Safety
This product complies with the following international safety standards:
Electromagnetic Compatibility (EMC)
This product complies with the following:
Korea EMC Statement (KCC)
EMC Statement in Korean text
BSMI EMC Statement - Taiwan
This is a Class A product. In a domestic environemnt this product may cause radio interference in which case the user may be required to take adequate measurers.
BSMI EMC Statement in Traditional Chinese text
