Example Configuration
Below is an example 802.1x Authentication via ISW to be authenticated by RADIUS server. In this basic example, we take port 1 as a testing port, which enables 802.1x in ISW.
With default configuration, use the following web UI settings:
  1. Navigate to Configuration Security Network NAS.
  2. Select Enabled mode to enable authentication.
  3. Set port1 and port2 as Port-based 802.1x.
  4. Navigate to Configuration SecurityAAARADIUS.
  5. Click Add New Server and enter 20.20.20.20 as the server and a1b2c3d4 as the secret key.
  6. Click Save.
