Follow these steps to apply a QoS DSCP-to-traffic class map to an ingress interface.
A QoS DSCP-to traffic class map must been configured.
For Extreme 8720, Extreme 8520, SLX 9250, and SLX 9150 devices, a Layer 2 switch port needs that the qos trust dscp be enabled before applying the qos dscp-to-traffic class map.
Similarly, on the Layer 2 switch port qos trust dscp cannot be disabled before removing the qos dscp-to-traffic class map.
device# configure terminal
device(config)# interface ethernet 1/2
device(conf-if-eth-1/2)# qos dscp-traffic-class dscpTcMap
device(conf-if-eth-1/2)# end
device# show qos maps dscp-traffic-class
Dscp-to-Traffic-Class map 'dscpTcMap'
{x/y: traffic-class = x, drop-precedence = y & dscp = d1d2}
d1 : d2 0 1 2 3 4 5 6 7 8 9
0 : 0/0 0/0 0/0 0/0 0/0 0/0 0/0 0/0 4/2 1/0
1 : 1/0 1/0 1/0 1/0 1/0 1/0 2/0 2/0 2/0 2/0
2 : 2/0 2/0 2/0 2/0 3/0 3/0 3/0 3/0 3/0 3/0
3 : 3/0 3/0 4/0 4/0 4/0 4/0 4/0 4/0 4/0 4/0
4 : 5/0 5/0 5/0 5/0 5/0 5/0 5/0 5/0 6/0 6/0
5 : 6/0 6/0 6/0 6/0 6/0 6/0 7/0 7/0 7/0 7/0
6 : 7/0 7/0 7/0 7/0
Enabled on the following interfaces: Eth 1/2
device# configure terminal device(config)# interface ethernet 1/2 device(conf-if-eth-1/2)# qos dscp-traffic-class dscpTcMap device(conf-if-eth-1/2)# end device# show qos maps dscp-traffic-class device# copy running-config startup-config
